We want to divide one project into two. The second project should have similar settings. How to do it in the cloud in the new interface ?
Hi Sergey,
When you create a project you can choose "Create with shared configuration". https://confluence.atlassian.com/adminjiracloud/creating-editing-and-deleting-projects-844500729.html
It will have the same schemes : issue type, workflow,... but not the same versions or components. That you'll need to create for the new project.
Thank you!
