Hi
I want to copy issues with tasks and subtasks to another epic.
They have the same tasks so I want to copy it.
I tried cloning it but cloning just allows to copy links.
I want the whole tasks and subtasks to be copied to another epic.
Is there any efficient way to do that?
Thank you.
Hello Ito, this functionality is not available with the standard features of Jira. You will need to install a third-party app. I recommend using DeepClone: https://marketplace.atlassian.com/apps/1218652/deep-clone-for-jira?tab=overview
Hello @Cristian0791, and welcome to the community, @Ito Miyu.
I am Marlene, product manager of Deep Clone for Jira.
Your use case is indeed possible with our app. If Deep Clone is installed on your instance, you must follow these steps:
Hello @Ito Miyu
If you're seeking for an easy way to clone an epic with all the tasks and subtasks, you can try our app Elements Copy & Sync that allows you to clone and sync a full hierarchy of issues with all their content (summary, description, custom fields, comments, attachments, etc).
You can check our guide here.
The app is for free during 30 days (and it stays free under 10 users).
Clara
