Hi Community,
I want to copy single issue picker field which is script runner field from Epic to it's child issues. I have tried Jira automation but this field is not supported in Automation rules.
Can any one suggest how should I achieve this?
Appreciate the help
Lot of features in Jira Cloud are missing in Jira Data Center
The following script can help you achieve what you are looking for:
If you have any questions, please let me know.
Best,
Fadoua
Hi @Issa
Please check these existing threads:
How to set multiple issue picker field via Automation for Jira
How can I fill a ScriptRunner Issue Picker field with a static value via Automation?
