how to create a filter that uses issue and sub-tasks fields together in one query
Sanjay Nanda
March 31, 2014
For e.g. I want to write a query that shows all subtasks assigned to me that are status!=committed and that have parent issue (for specific fix version & in committed state)
Tarun Sapra
Are you using ondemand or self-hosted JIRA, as you would need Script Runner plugin for these kind of searches. Script runner plugin is only available on self-hosted.
see here- https://jamieechlin.atlassian.net/wiki/display/GRV/Scripted+JQL+Functions#ScriptedJQLFunctions-Subtasks
Sanjay Nanda
March 31, 2014
Thanks Tarun and Sakthi for the reply. I could use Script Runner to achieve this. Below is the query:
issueFunction in subtasksOf("status = Committed") AND status != Committed AND assignee = <loginid>
Sakthi Balaji March 31, 2014
Hi Sanjay,
can you pls try with this JQL QUery in the advance search issues screen
project = "project_name" and status != "ur required status" and issue in subtaskIssuesFromQuery("project = 'project_name' and status = 'ur required status' ")
You can add assignee ="ur name in the query"
and whatever criteria you wanted in the query
