how to default name field on Jira issue collector form
Sreerampavankumar Govindarajula
October 27, 2020
Hi  I am trying to use Jira issue collector form with custom trigger and using below java script to default values. Want to know how to default 'Name' field. Tried using 'name' under the fieldValues section but its not recognizing it.  Can some one pls tell  me what is the name for that field as the form is not recognizing 'name'
<script type="text/javascript">
window.ATL_JQ_PAGE_PROPS = {
"triggerFunction": function(showCollectorDialog) {
//Requires that jQuery is available!
jQuery("#feedback-button").click(function(e) {
e.preventDefault();
showCollectorDialog();
fieldValues: {
summary : 'Feedback for new website designs',
description : 'The font doesn\'t quite look right',
email : 'abc@def.com',
</script>
October 29, 2020
I found answer for my own question. I launched the collector form and then used chrome inspect to see the element details for the form and found the name as "fullname" and now able to set it
fieldValues: {
fullname : 'test',
