×while trying to export issues from jira instance to openjira I am getting error.
Hi @DH20275693 , the limit previously was 1000 results.
You need to split the issue search via a filter criteria into chunks lower than your limit, export twice and then merge the results again.
Hi, can you share the current JQL of the filter results you would like to export?
Under Issues > Search for issues determine the criteria of issues you would like to export. Then switch to Advanced to see the JQL.
See also: Advanced searching
@Dave Mathijs Hi Dave, I have the same problem. But I do not have any more filters to split and merge. This is what my JQL looks like- project = PCR AND issuetype = "Documentation Change" AND status in (Implemented) AND "PCR Context" = P6700 ORDER BY created DESC, priority ASC
How can I export the results then? My results are getting closer to 2k and I'm afraid I don't have anyone locally that has been able to resolve this issue. Pls help.
Hi @DH20275693
In addition to @Dave Mathijs response, you can also check this KB. You will again need to merge the results.
