×Hi All,
we would like to find the paid plugins which are being used by projects.
Please let us know if there is any way to find this.
With that regard, does anybody know how to track where (which project/workflow/filter) a plugin is being used?
There is no way to do this en-masse, you have to look at what each plugin provides, then track that down. Many plugins won't even have a clear link to a specific project either.
You basically have three options
I strongly recommend the middle option on that list (backed up with a threat of the third if no-one talks to you)
Hi @Sandhya ,
While the comprehensive list of Nic applies, you could check out an app supported approach using Admin Toolbox for Jira and its built-in Workflow Report to get statistics on the 3rd party app usage within your workflows.
Cheers
Thorsten
Hi All,
any updates on how to check the Plugin Usage in Jira Cloud ?
Cheers
Skander
The answers for 2019 still stand!
Although I'd add another to @Thorsten Letschert _Decadis AG_ 's list from then - Adaptavist's Microscope is designed for Cloud migrations and helping admins housekeep, but it lists all the app usage it possibly can.
