hi,
i have 3 projects and i try to get issue by project id.
but it return all issues overall project.
i want issues as per project id.
i have tried following API :
i have issue assigned in 10010 but if i put 10000 then also i get same response.
assignee = username and project=10010 AND status in ("In Progress", "To Do") AND resolution = Unresolved order by updated DESC
i got results by this query thanks for support
I have a project that is specifically to include all of our projects. JQL is:
project in (AB, DED,CC P, MNO) ORDER BY priority DESC, Rank ASC
Hi @akshay.dongave ,
Could you try with project key instead of id?
