I want to use a "send custom email" post-function with script runner. In the body of my email, I would like to get the issue key of eventual linked issue.
Any ideas please ?
Melissa
I used the following code in the "Email template" section. It loops through the Linked Issues and builds out a list of linked issues (Please excuse the code as I don't claim to be a developer by any means :)).
I hope this helps. ...Cheers!
<b>Linked Issues:</b> <br>
<ul>
def outwardlinks = com.atlassian.jira.component.ComponentAccessor.getIssueLinkManager().getOutwardLinks(issue.getId())
def inwardlinks = com.atlassian.jira.component.ComponentAccessor.getIssueLinkManager().getInwardLinks(issue.getId())
def oCounter=0
def iCounter=0
// Check for Outward Links...
if (outwardlinks)
for (id in outwardlinks) {
def linkedissueKey = com.atlassian.jira.component.ComponentAccessor.getIssueManager().getIssueObject(outwardlinks[oCounter].destinationId).key
def linkedissueSummary = com.atlassian.jira.component.ComponentAccessor.getIssueManager().getIssueObject(outwardlinks[oCounter].destinationId).summary
def linkedissueStatus = com.atlassian.jira.component.ComponentAccessor.getIssueManager().getIssueObject(outwardlinks[oCounter].destinationId).status.name
out << "<li><a href='https://jira.domain.com/browse/"+linkedissueKey+"'>"+linkedissueKey+"</a> "
out << "("+linkedissueStatus+"):"
out << linkedissueSummary+"</li><br>"
oCounter ++
// Check for Inward Links...
if (inwardlinks)
for (id in inwardlinks) {
def linkedissueKey = com.atlassian.jira.component.ComponentAccessor.getIssueManager().getIssueObject(inwardlinks[iCounter].sourceId).key
def linkedissueSummary = com.atlassian.jira.component.ComponentAccessor.getIssueManager().getIssueObject(inwardlinks[iCounter].sourceId).summary
def linkedissueStatus = com.atlassian.jira.component.ComponentAccessor.getIssueManager().getIssueObject(inwardlinks[iCounter].sourceId).status.name
iCounter ++
</ul>
What does "eventual linked issue" actually mean? This can be quite complex.
You can get all linked issues like this
Hi both, @Jamie Echlin [Adaptavist] @Vasiliy Zverev
thanks for your answer. Do not pay attention to the "eventual" liked issues. sorry it was confusing and does not matter.
here is my email and what I tried to show the linked issue reference thanks to Vasiliy's comment: (send custom email post-function script). But it returned into a script error. Any ideas? thanks for your help
<p>Dear all,</p>
<p>For your information, this NPC study has been reviewed with your teams. Please find attached the detailed Impact Analysis.</p> <p>You can also log in directly our tool JIRA: <a> "https://aptp-alm.accenture.com/jira/browse/$issue.key"</a></p>
<p>Summary: ${issue.summary}</p>
<p>Description: ${issue.description}*</p>
<p>SCOPE restriction:</p>
<p>CAP volume:</p>
<p>First trade planned:</p>
<p>IT development:</p>
<p><% out << issue.getCustomFieldValue(componentAccessor.getIssueLinkManager().getOutwardLinks(issue.getId())%></p>
<p>Best Regards,</p>
<p>NPC team
Can you remove the "issue.getCustomFieldValue", not sure why you have that.
