how to index jira project
YassineM January 13, 2015
How can i index only one specific JIRA project?
Elisa [Atlassian]
January 13, 2015
Hi Yassine,
You can reindex a single project by:
  1. Visit the project
  2. Click on the administrator tab
  3. Click on the gray Actions button >> Reindex project
That should do the trick! smile
Cheers!
Fadoua Boualem October 6, 2015
Hi Elisa,
What does a project re-indexing do exactly please?
Best,
Fadoua Boualem
Piyush_Annadate
re-indexing a single project - does that affects projects performance (accessing project while re-indexing)?
Prashant Mali
July 27, 2018
If we start two re-indexing simultaneously , Does it impact on JIRA performance?
Thanks in Advance.
Piyush_Annadate
re-indexing application simultaneously - not possible.; but re-indexing project can.
Vickey Palzor Lepcha
July 27, 2018
@Piyush_Annadate It is possible.
July 27, 2018
@Prashant Mali Depends on the amount of data those two projects would contain.
Piyush_Annadate
just updated my comments- thought about jira app re-indexing. I did re-indexing project with 3k, 9k and 1k - no issues for me with performance at any node.
Prashant Mali
July 29, 2018
Thanks for update...
Timothy Bassett
Just to clarify here, this is not relevant for current JIRA as reindexing does not exist.
Sam
Hello YassineM, to re-index a specific project, you would navigate to the project in question, click on "Project Settings", and then click "Re-index project". You should then see a button that says "Start project re-index". Click on that button, and confirm you want to start the project re-index.
That should allow you to re-index that particular project. Please let me know if that helps!
