I need a drop-down box ,that can list a project all issues.
and when I select a issue with this drop-down box ,the selected issue 's field value can copy to current issue's field.
E.g:
project-A needs a drop-down field, which can list all issues of project-B, and proejct-B issue contains some fields (office, department),
Create a new issue in project-A, which also contains fields (office, department),
when select issue-B-1 through the drop-down box, and then the field value can be automatically copied.
Do someone know how to do it. This should actually be two questions:
1. the drop-down box how to list a project issues?(the project could be fixed)
2. when select a issue ,how to copy the field values?
Hi @yundong.li ,
Using ScriptRunner requires some scripting abilities, so if you aren't able to do it on your own, you can contact an Atlassian Partner of your choice, and order such service.
Radek Cichocki
