how to make field read-only except certain project role and certain step at the same time?
Kate
For example, I have project roles: Developers, Users.
I want to make my field read-only except on step "In Progress" for Developers, and except on step "Open" for Users.
As a result: ("In Progress" AND Developers) OR ("Open" AND Users).
Help, please :)
sbhutada
Rambanam Prasad
I am trying to make a text field read only on edit screen, but looks like the code is not working. can you please help with this -
jQuery(document).ready(function($) {
JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function(e,context) {
var projectName = AJS.$("#project-name-val").text();
console.log("RFC projectName "+projectName);
if (projectName == "RFC")
callReadonlyFunction();
function callReadonlyFunction(){
$('#edit-issue').click(function() {
           console.log("Edit Button Clicked Start");
           AJS.$("#customfield_13911").attr("readonly", true); //text field
           console.log("Edit Button Clicked End");
In the console log, I do see messages but for some reason, the field is not becoming read-only.
Joe Pitt
the behavior plug-in may offer that, but I don't know if you can have it installed.
Deleted user November 3, 2013
Jira on demand?
RambanamP
August 1, 2013
the following script will run on edit screen
<script type="text/javascript">
JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e,context) {
		makeReadonly();
		makeReadonly();
function makeReadonly(){
		var editFunction=$('#edit-issue-submit').val();
	if(editFunction === 'Update'){
        var user=getCurrentUserName();
		var statusText=$('#status-val').text();
		var status=$.trim(statusText);
		var devlopersRoleID='10010';//changr the project role id here
		var usersRoleID='10011';//changr the project role id here
		$("#customfield_10571").attr("readonly", '');
		$("#customfield_10572").attr("readonly", '');
		if(isUserInGroup(user,devlopersRoleID) && status=='In Progress'){
			//to make text field read only
			$("#customfield_10571").attr("readonly", true);
		}else if(isUserInGroup(user,usersRoleID) && status=='Open'){
			$("#customfield_10572").attr("readonly", true);
function getCurrentUserName()
var user;
     AJS.$.ajax({
        url: "/rest/gadget/1.0/currentUser",
        type: 'get',
        dataType: 'json',
        async: false,
        success: function(data) {
            user = data.username;
     return user;
function getUsers(roleID)
var users;
     AJS.$.ajax({
        url: "/rest/api/2/project/TEST/role/"+roleID,//change project Key here(need to replace TEST with your project key)
        type: 'get',
        dataType: 'json',
        async: false,
            users = data.actors.name;
     return users;
function isUserInGroup(user, roleID){
    var users = getUsers(roleID);
    for (i = 0; i < users.length; i++){
         if (users[i].name == user){
              return true;
    return false;
</script>
Kate
wow, it looks nice! :)
And how can I get system fields? Duedate, assignee..
RambanamP
August 1, 2013
try with following code
//for dute field
$("#duedate").attr("readonly", true);
//to hide date picker icon
$("#duedate-trigger").hide();
/to show date picker icon
$("#duedate-trigger").show();
try with this for assignee field
$("#assignee-field").attr("readonly", true);
Kate
I guess function isUserInGroup(user, roleID) doesn't work.
Without this function all is ok..
RambanamP
August 14, 2013
check the REST API in isUserInGroup(user, roleID) function
Kate
only on Edit Screen..
RambanamP
July 31, 2013
small clarification!
do you want field read only on transition screen or view screen?
Kate
I'm not sure that it will work excellent. But I'm ready to try.
How can I get projectrole and step using javascript?..
RambanamP
July 31, 2013
you can do it by using javascript? let me know if you want do it using JS so i can help you!!
