how to purchase zephyr for jira test management add-on for Jira in India
Yuvraj Hole December 2, 2014
Hi Team,
We have to purchase zephyr for jira test management add-on for JIRA but when we tried to purchase through below link we found ADD to Cart option is disabled. We are working from INDIA. so please help us how we can purchase this add-on.
https://marketplace.atlassian.com/plugins/com.thed.zephyr.je
Geert Graat
December 2, 2014
Did you select a user tier (manual)?
If you already own a JIRA license which is attached to your account, the JIRA user tier is automatically selected. Otherwise you can manually select a user tier. Then the add to cart option is enabled.
Your location does not matter for purchasing this addon as far as I know.
Regards
Geert
