how to retrieve labels for a project based on projectId/projectKey using jira API?
Peter March 3, 2021
Hi, Can someone share details on how to retrieve labels related to particular project, based on projectID or project Key.
Thanks.
Fabio Racobaldo _Catworkx_
Hi @Peter ,
unfortunately labels are not associated to a specific project. In order to retrieve labels used in a specific project you could retrieve via REST API (BASEURL/rest/api/2/search?jql=YOUR_JQL_HERE) all issues in a project with labels and collect them.
Fabio
Peter March 3, 2021
Hi Fabio. Thanks for your response. JQL works. Wanted to check if there is a way to retrieve data based on project.
Thanks!!
