I need to add person with only permission to work with tasks he assigned
How can i do this?
Hi Ilya,
not sure what you're asking, there are multiple interpretations on this.
When somebody is assigned to a ticket and you want them to be the only one to move it to another status, this can be done through Workflows.
If you're able to:
This should do the trick. Now only the assignee can do the transition.
Yes and to add more restrictions modify the permission scheme used in the project to add "Current Assignee" for the relevant permissions.
Hi, Ravi! Thanks for the answer, it's what I need.
