×while using Clone and Move option in Jira, summary fields is not getting prefix as 'CLONE'
Where as in the Clone option in Jira, by default, "CLONE' is prefix in summary.
what is the way to set the prefix as default in Clone and Move
Hi Mahmood,
You can do with the following steps
Edit the value of the "jira.clone.prefix"property by clicking the existing value and specifying a different prefix for the 'Summary' field of cloned issues.
Click the 'Update' button to save the new value in the JIRA database.
Mehmet Sirin
Thank you Mehmet,
the given solution will update only for 'Clone' but not for using 'Clone and Move' plugin.
so even after modifying the "jira.clone.prefix"property, Prefix is not appearing on using Clone and Move option.
Thanks and Regards,
Mahmood
