how we can use checklist ID in Jira automation
Archana Singh August 23, 2025
Hi Team,
I wanted to find out the ID of a checklist in Jira so I can add it to an automation - would it be possible? where we are using checklist as Jira addon .
I need  assistance on this.
Fazila Ashraf
Hi @Archana Singh
Which checklist related plugin do you use? Can you give an example also on what you want to add it in automation?
Yuliia Tkachenko_TitanApps_
Hi @Archana Singh
If you're using Smart Checklist for Jira, here's how you can find Templates ID directly from the issue view:
  1. Open any Issue with the Smart Checklist applied.
  2. Click on the 3-dots menu.
  3. Select Manage templates/Import from a template.
  4. Expand the template you are looking for.
  5. Template ID field is on the right of the template name
Read more about using Smart Checklist in Automation for Jira here
