https JIRA "weak ephemeral Diffie-Hellman public key”
KP11
September 4, 2015
I have read several articles that state to upgrade to java 1.8 and add
-Djdk.tls.ephemeralDHKeySize=2048 in tomcat startup.
Some articles say JIRA 5.2.4.1 does not work with Java 1.8.. We are upgrading end of year to cloud
Can this  issue be related to certifcates as well. We need to fix the issue before the upgrade. Any other workarounds  besides Java upgrade?
no_longer_in_sudoers_file
September 4, 2015
Have you considered putting nginx or apache in front of your JIRA instance to abstract away your SSL handling from JAVA?  This gives you a few more tools for managing these problems.
KP11
September 4, 2015
We can test that on our dev system. Thanks
KP11
September 4, 2015
I saw this workaround. It does notdetail where exactly the line goes To workaround the problem, please add the cipher below to disable the weak Diffie-Hellman cipher. Open server.xml via $JIRA_INSTALL/conf directory. Add the following to the HTTPS connector port: ciphers="TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256,TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA,TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384,TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA,TLS_RSA_WITH_AES_128_CBC_SHA256,TLS_RSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_256_CBC_SHA256,TLS_RSA_WITH_AES_256_CBC_SHA" (info) Reference for more strong cipher settings - Security tools report the default SSL Ciphers are too weak Save it and restart JIRA. https://confluence.atlassian.com/display/JIRAKB/Server+has+a+weak,+ephemeral+Diffie-Hellman+public+key
Nic Brough -Adaptavist-
September 4, 2015
I'm afraid not, if you want to upgrade Java, you need to upgrade Jira.
KP11
September 4, 2015
KP11
September 4, 2015
<Connector port="8963" maxHttpHeaderSize="8192" protocol="org.apache.coyote.http11.Http11Protocol" maxThreads="150" minSpareThreads="25" maxSpareThreads="75" enableLookups="false" disableUploadTimeout="true" acceptCount="100" scheme="https" secure="true" sslProtocol="TLSv1" sslEnabledProtocols="TLSv1.2,TLSv1.1,TLSv1" clientAuth="false" SSLEnabled="true" URIEncoding="UTF-8" keyAlias="server" keystoreFile="conf/jira.jks" keystorePass="solumina" ciphers="TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_DHE_RSA_WITH_AES_128_GCM_SHA256,TLS_DHE_DSS_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_128_SHA256,TLS_ECDHE_ECDSA_WITH_AES_128_SHA256, TLS_ECDHE_RSA_WITH_AES_128_SHA,TLS_ECDHE_ECDSA_WITH_AES_128_SHA, TLS_ECDHE_RSA_WITH_AES_256_SHA384,TLS_ECDHE_ECDSA_WITH_AES_256_SHA384, TLS_ECDHE_RSA_WITH_AES_256_SHA,TLS_ECDHE_ECDSA_WITH_AES_256_SHA, TLS_DHE_RSA_WITH_AES_128_SHA256,TLS_DHE_RSA_WITH_AES_128_SHA, TLS_DHE_DSS_WITH_AES_128_SHA256,TLS_DHE_RSA_WITH_AES_256_SHA256, TLS_DHE_DSS_WITH_AES_256_SHA,TLS_DHE_RSA_WITH_AES_256_SHA"
KP11
September 4, 2015
There is already a cipher key.
KP11
September 4, 2015
I was going to add it to the line? Any know issues with this workaround?
