i am not able to try jira after adding website name i am getting error i have tried 3-4 times, i am seeing error as 'something wrong happened at our end ' and the issue id is
238fa0e5d395448cacaaf6763bf29cfb
still same issue
Hey @Manik Lakhwani
Welcome to the community!
The "at our end" part suggests it's could be a glitch on Atlassian's side, but you could try clearing your browser's cache and cookies or using incognito mode, just in case.
If that doesn't work, I'd recommend heading over to the Atlassian Support portal: https://support.atlassian.com/contact and raising a ticket with the details. Be sure to mention that issue ID so they can track it down.
Hope this helps!
