i couldn't able to create a ticket , plz help me for it
Sai Prasanna Kumar
August 17, 2023
when iam trying to create a ticket i got some errors like
Error 1 - "Fix Version/s" field is required and the project "PROJECT" does not have any versions.
Error 2 - Fix Versions/s: Fix Versions/s is required
Deepak Jain
Hi @Sai Prasanna Kumar ,
Welcome to the Atlassian Community !!
I understand you are trying to create a ticket in Jira but getting errors.
Seems in your Jira project, Fix Version/s field is set as required field. And there is no versions created in your project. Kindly check with your project/Jira administrator to see where this field is set required (either on "Field configuration scheme" or on workflow).
Right not you won't be able to create issues until this field is marked optional (Instead of required).
Hope this helps !!
Deepak
SERVER
