i'm trying to enable the road map for my epics, but i don't see a feature click option in the project setting.
its this an add on feature?
Hi Lekshmi.
Welcome to the Atlassian Community.
The road map feature is only available for next gen projects.
To get there, when creating a project select the Nextgen template.
how do i select nextgen template, is that an add on?
you "Create Project" then in the next step you select the template you want to use. NOTE: you must be on Cloud as next-gen is not available in server.
can i change an existing project to next-gen project
No but you can create a new next-gen project and then bulk move all issues into it from your classic project.
