i need to move my jira and bitbucket to https
Igor Bezukh
June 5, 2018
i got certificates from let'sencrypt , but i cant understand how simply import them to jira and bitbucket , i need some help .
Marcos PS [DEISER]
Hi Igor,
The best solution comes by creating a reverse proxy over Apache (you also can use Nginx, F5 or whatever you have/like but if you want a supported platform and with a good documentation availability you should use Apache 2.2+)
Here you have almost you have to know about this integration. Remember you also have to add the certificate to the Tomcat true-store, you can do it using this command:
keytool -import -file YourSiteCertificate.cer -alias WhateverYouLike -keystore "%JAVA_HOME%\lib\security\cacerts"
Hope this helps you on your task.
Best regards,
Marcos.
PS: Almost the same procedure applies to Bitbucket.
Igor Bezukh
June 5, 2018
thanks !!
Yogesh Mude
June 5, 2018
