increase width of project and issue type box
Neeta Dubey
Is there a way i can increase width of project and issue type box? I am attaching the screen shot.please do let me know if you need further info.
rambabu patina
January 5, 2014
Neeta Dubey
Thanks this helps in increasing the widht of project...how to increase width of issue type.
Neeta Dubey
HI ram,
i made some in the announcemnt banner now i couldnt see the dash board or the create issue but...attching the screen could you please let me know how i can revert the settings?
rambabu patina
January 6, 2014
Did you tried in test instance or in production. For modifications every time need to take the backup. If you have the backup then backout the changes.
Please check the <script> tags ended properly or not in the announcement banner.
Neeta Dubey
i tired this in testing enviroment. The page itself is not opening so i cant do much changes. i alslo followed the steps in this doc but that is also not working.
https://confluence.atlassian.com/display/JIRAKB/JIRA+pages+go+hidden+and+unusable+via+Announcement+Banner
RambanamP
January 6, 2014
no there is no attachment here, attach a screen shot to answer intead of comment it may work!!
Neeta Dubey
attaching screen shot
Neeta Dubey
Neeta Dubey
for some reason attachment is not getting attached however...the page looks same as the snap shot in this doc
RambanamP
January 6, 2014
did you seen my comment on my answer?
you need to check error log by opening javascript console on chrome or firebug console on firefox
rambabu patina
January 6, 2014
@Neeta: Please check the all tags ended properly or not.
For Ex: <script> shoul end with </script>
Harish Tuccapuram
Hi
The script doesn't work for me, when i have tried adding the above mentioned script in Jira Server 7.9.2 version it doesn't work for some how.
Can someone help me out how to fix this?
Radek Janata
Add the following into the Announcement Banner:
<style>
#project-single-select, #project-field {
max-width: 500px !important; }
</style>
Like # people like this
Harish Tuccapuram
Thanks @Radek Janata!
Neeta Dubey
This is resolved. i need to restart the appliation after making the changes.
RambanamP
January 5, 2014
to increse the project field width check this Q
https://answers.atlassian.com/questions/237452/jira-6-increase-display-width-of-field-project-during-issue-creation
final script will be as follows
&lt;script type="text/javascript"&gt;
jQuery(document).ready(function($) {
    JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e,context) {
                callFunction();
            callFunction();
function callFunction(){
				//for project field
				$('#project-single-select').css('max-width','500px');
                $('#project-single-select').css('width','500px');
                $('#project-field').css('max-width','500px');
                $('#project-field').css('width','500px');
				//for issuetype field
                $('#issuetype-single-select').css('max-width','500px');
                $('#issuetype-single-select').css('width','500px');
                $('#issuetype-field').css('max-width','500px');
                $('#issuetype-field').css('width','500px');
&lt;/script&gt;
load it as webresource module in a plugin (add it on announcement banner to test)
RambanamP
January 5, 2014
@Neeta, i did't find any screenshot!!
can you check what is the error message showing in javascript console on chrome or firebug console on firefox
Pawel Bojkowski October 21, 2016
The result here in our cloud version is this...but why?
image2016-10-21 15:36:36.png
Nic Brough -Adaptavist-
October 21, 2016
Because Cloud blocks customisations like that (Server is increasingly doing it too)
January 5, 2014
You'll need to amend the code that generates the html for the width of the boxes. Possibly in more than one place for those fields.
