Hi
I just installed jira on a linux / debian server
It's a "regular" version, not with test liscences.
I installed the Jira Mobile Connect SDK and it seems to be fine, but I just can't get the "Jira Mobile connect" section in my project configuration. I removed and retried, without any success
I am using very last version of server, I can't figure out why it's not woking
where could I look to understand why it's not working ?
regards
greg
Is there any error message in your logs? Also, are you sure that your machine is accepting connections from the outside (i.e. an iPhone)? Also, which version of JIRA and JIRA Mobile Connect are you using?
and Jira is v5.0.2#725-sha1:5735107
Debian 32 bits, up to date, internal db
the problem is at server side, I installed the plugin but in project configuration I don't any entry for the Jira mobile connect
for more details it's jconnect-plugin 1.0.11
In project / Settings I can't see Jira mobile configuration while it should as explianed in page
https://developer.atlassian.com/display/JMC/Enabling+JIRA+Mobile+Connect
step 2, rank 3
is I have CSV Modules but no Jora connect :-(
I removed and re install without any success
greg
resolved : for Jira 5 I must install Jira mobile connect 1.1 and not version 1.0.11 as generaly proposed
Hi Gregoire,
Apologies about the mix-up between versions. The APIs in JIRA 5.0 have changed since JIRA 4.4.x and we needed to release two separate versions of the plugin. As you discovered, JIRA 5.0 uses JMC 1.1, not JMC 1.0.11.
As a result, I will ensure that the JIRA 5.0 version of JMC is the suggested version on plugins.atlassian.com
Cheers
Josh
Hi Gregoire,
Cheers
Josh
