is there a way to export a single project from jira and import that single project into another jira instance
Sriveni Kokkonda
I have a project in my test environment and i would like to move this project to another JIRA instance. What is the procedure to export a single project from one JIRA instance to another JIRA instance.
It would be really helpful for us.
Sriveni.
Christian Peper August 18, 2016
I've recently come across an addon that lets you do things in a TST environment and then export the changes to your ACC/PRD server in a packaged way:
https://marketplace.atlassian.com/plugins/com.botronsoft.jira.configurationmanager/server/overview
we are currently evaluating if we want to use this too
Peter Bengov
November 12, 2014
Hey Sriveni, please follow Nic's answer here: https://answers.atlassian.com/questions/109233
Jobin Kuruvilla [Adaptavist]
November 12, 2014
You have to take a full back up and restore the project that you want to import. See https://confluence.atlassian.com/display/JIRA/Restoring+a+Project+from+Backup
Your JIRA's and plugins must be on the same version for this to work.
