is there a way to iterate values from the list using the smart values?
Devarajan Mani
I need to iterate the name, date and time values from the below and update the respective custom fields in Jira cloud.
{accountId=712020:87072582-f63b-429d-8af6-c963148b3432, meaning=Approval, name=Karthikeyan Ponnusamy Jayachandran, status=Approved, title=Lead, date=Apr 3, 2025, time=8:21 PM, ts=2025-04-03T13:21:58Z}
Thanks in advance
Bill Sheboy
April 3, 2025
Hi @Devarajan Mani
How many records are you expecting for what you show: one-and-only-one, zero-to-many, etc.?
  • When there is one-and-only-one record, I recommend using text functions, such as match() with a regular expression, to extract the information: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/
  • When are an unknown number of records, that list would need to be parsed / iterated first to extract the information.  And as you describe setting custom field values, that may not be able to both iterate issues and iterate the data.
After you clarify the scenario, that will help the community to offer better suggestions.
Kim Euker
Hi, yes you can.
First off, when putting the data into your smart value, I would strip off the starting and ending
{ } leaving you with the value pairs.
Then using advanced branching, step through each of the value pairs like this.  Each time through the branch you will have a new pair.2025-04-03_09-37-32.png
