is there a way to refer to a teststep within an action of another teststep?
Jos Hollaar
September 18, 2024
In a teststep of an XRay testcase, I want to have "repeat step X1 and X2 with condition X"
But because I also use to call another testcase the steps in the execution are numbered differently than in the design.
Is there something like a variable to use?
Manuel
October 19, 2024
You can add a step that calls another Test as detailed here.
That is the way Xray allows you to do it; however you cannot call a specific step of another test or even refer explicitly to another step within the same Test.
Answering directly to your question, there is nothing that provides something like that out-of-the-box.
You could abstract some sequential steps as a Test itself.. and then use it as a modular test. However, depending on the concrete use case, that could not make sense at all.
