issue field does not appear
uday
Hi All,
 I have created one standard issue type and configured to project issue type scheme. But while creating a ticket the issue type does not appear.
Thanks and Regards
Uday
Alexander Bondarev
April 30, 2021
Hi, @uday !
It looks like customization, like Live Fields from Power Scripts or Behaviors from Scriptrunner, etc.
Do you have any external apps?
Vikrant Yadav
Hi @uday Check the issue type scheme for the project .
Note that only standard issue types can be created with no parent using the top Create Button.
Others need to be created within a parent issue (that is on the issue view screen using Creating Subtask menu)
What kind of issue type is the missed one? Standard or Subtask?
See Administration >> Issue Types: If Standard --
See Behaviours included within Script Runner for Jira, Issue Type Filters (and Security) application or any of this kind.
KR,
Vikrant Yadav
Kevin Johnson
Hi @uday ,
As you say there is only one standard issue type, so there are not options to choose. If you still think it is a problem, explain a bit and share a screenshot or picture of it.
-Kevin.
uday
Hello Kevin,
So there are multiple issue types for the project but while selecting specific standard issue type it does not appear to choose issue type.
- uday
Like Kevin Johnson likes this
Kevin Johnson
@uday okay, but can you share an image to understand the issue better?
-Kevin.
