I would like to see the hierachy of my issues somewhere (tree). My issues are grouped like the following
Epic 1
-> sub task
-> Story 1
-> sub task
-> Story 2
-> sub task
-> sub task
Is there a way to see all of this at once and be able to click on any of the issues?
Raoul, you might want to check our Structure plugin: https://marketplace.atlassian.com/34717
You can try it with a free evaluation license. After you've installed the plugin, to get this hierarchy, you need to:
Let us know if you need more help with this.
Igor
Disclosure: I work for the company behind Structure plugin.
I am currently testing out Structure in my dev instance - I am really liking it so far. :)
Thanks Luc, but my version is on the cloud not server. I was able to figure the structure I needed out.
Raoul,
Please take a look at Impact for JIRA (http://bit.ly/1tYPzxu) which can do that.
Luc
