issue key duplicates in comment field
fjodors
August 13, 2012
Hello
Issue key duplicates in comment field when I am writing a comment. For example, I added comment and wrote the issue key in comment field. As a result this comment was added with duplicate issue key text (see image)
http://postimage.org/image/lab582c75/.
Could you please explain to me how to solve this problem?
Thanks!
Faisal
August 15, 2012
Hi Fyodor,
One of my colleague has recently verified this behavior, and have filed this as a bug. Kindly refer to the bug report for more info:
- https://jira.atlassian.com/browse/JRA-29353
I have my suspicion that this could arise when we use the character "-" in the issue key.
Though it's not much, but I hope that the info helps.
Best regards.
fjodors
August 15, 2012
Hi Ahmad
Thank you for support, I'll review this ticket and will vote for it.
BR,
Fyodor
Faisal
August 14, 2012
Hi Fyodor,
At the moment I am unable to reproduce the exact behavior on JIRA 5, but this looks like a bug. May I know how did you reproduced it? Which JIRA version are you currently running on? Did you make any changes to the project key pattern?
The problem, is it easily reproducible on other issues as well?
Thanks.
fjodors
August 14, 2012
Hello, Ahmad
Thank you for reply.
JIRA version is 4.4.3
jita.projectkey.pattern is (([A-Z0-9]{0,5}-)?([0-9]{4})){1}
Issue key duplicates in comment field when I am writing comments in other issues also.
BR,
Fyodor
