issue with 'Cumulative Flow Diagram' column description hiding number resolution at the end diagram
urban.marklund
May 20, 2020
Hi Community,
No problem to use the standard reporting based on displayed Kanban board.
Today I discover the column description  fields hiding the full table resolution of number of issues right side of the table. The amount of 'columns' are 12 and last month with the same browser was no problem, the column description was just the length of the Column description, now its ful page.
I have tested Firefox/Chrome and IE with the same result of type issue, The data are correct but the presentation are not easy to read.
Anyone have experience this before?
Bill Sheboy
June 25, 2020
Hi @urban.marklund
Would you please post an image of what you are seeing?  Thanks!
Best regards,
