java -Djira.jelly.on=true ... where to paste it in bin to enable my jelly ?
vishwash kumar February 2, 2012
i am not able to access, i can use jira at local host just by going to itsURL. i need top enable jelly in jira. how can i do this ?
DanielG
May 29, 2013
If you are using Linux system, you have to edit 'setenv.sh' and put:
JVM_REQUIRED_ARGS="-Djava.awt.headless=true -Djira.jelly.on=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true"
Hope it helps,
Daniel
Tamir Lavi May 29, 2013
Even better solution:
run (5.2 ver.)
tomcat7 //US//service_name ++JvmOptions="-Djira.jelly.on=true"
Or (for 5.0 and lower)
tomcat6 //US//service_name ++JvmOptions="-Djira.jelly.on=true"
Where service_name is the service code e.g.: <tt>JIRA060611143045</tt>
For anyone (like me) that ever come accross that post.
There are several ways to do that.
Here is one:
Identify the name of the service that JIRA is installed as in Windows (<tt>Control Panel > Administrative Tools > Services</tt> ):
Find the JIRA service and double click to open the dialog box. The look for theSERVICENAME e.g.: <tt>JIRA060611143045</tt>
Close this dialog
Open a command window, and <tt>cd</tt> to the <tt>bin</tt> directory of the JIRA instance
Run: <tt>tomcat6w //ES//%SERVICENAME%</tt>. e.g.
tomcat6w //ES//JIRA060611143045
Click on the Java tab to see the list of current start-up options:
Append any new option on its own new line by adding to the end of the existing Java Options.
Then close and restart the JIRA service. Jelly should now be enabled
Originaly from https://answers.atlassian.com/questions/1843/jelly-runner
You can also add that line (in seperate line):
To the to Java options in the service registry, if you know how.
Tamir.
Andy Brook [Plugin People]
February 2, 2012
are you running jelly as a windows service (there are different instructions). Failing that, check the JVM argument is visible through your JRIA admin console?
i have installed jira bon my system. i m moving to program files->atlassian >jira > bin and modifying this document "setenv" by pasting it java (-Djira.jelly.on=true ). and restrated jira ...but i was not able to enable jelly runner
February 2, 2012
You dont answer eitehr of the points I raise?
