Hello!
We're currently running into an issue when setting up an IMAP configuration for incoming emails on our JIRA Server. We have an account hosted at outlook.office365.com, and we can see the following options for connecting via POP or IMAP
POP
Server name: outlook.office365.com
Port: 995
Encryption method: TLS
IMAP
Port: 993
We've used the these parameters to set up an IMAP server on our AWS Jira instance:
Protocol: SECURE_IMAP
Host Name: outlook.office365.com
IMAP Port: 993
Timeout 20000
Username: username@<domain>.com
When trying to test the connection, we receive this message:
Unfortunately no connection was possible. Review the errors below and rectify:
We've tried the following to troubleshoot:
[c.a.j.p.mail.webwork.VerifyMailServer] Unable to connect to the server at outlook.office365.com due to the following exception: java.net.SocketException: Connection reset
openssl s_client -connect outlook.office365.com:993 -crlf -servername outlook.office365.com
subject=/C=US/ST=Washington/L=Redmond/O=Microsoft Corporation/CN=outlook.com
issuer=/C=US/O=DigiCert Inc/CN=DigiCert Cloud Services CA-1
No client certificate CA names sent
Peer signing digest: SHA1
Server Temp Key: ECDH, P-256, 256 bits
SSL handshake has read 3863 bytes and written 461 bytes
New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES256-GCM-SHA384
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
CONNECTED(00000003)
write:errno=104
no peer certificate available
SSL handshake has read 0 bytes and written 319 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg : None
Krb5 Principal: None
PSK identity: None
PSK identity hint: None
Start Time: 1546003282
Timeout : 300 (sec)
Verify return code: 0 (ok)
Has anyone run into similar issues?
UPDATE:
After doing a little bit of testing, it looks like I can connect to outlook.office365.com IMAP from an instance in a public subnet. However, our Jira instance is located in a private subnet. Has anyone tried configuring an IMAP server for a Jira instance hosted in a private subnet? Thanks again!
We're having a similar issue. I think it's due to the firewall blocking office365.com on the server.
But I suspect that another cause might be that we're running our test JIRA inside our network using http, not https. In the past we connected to Incoming email servers using IMAP, not Secure_IMAP. But office365 requires https, and I'm guessing that it's not allowed from an http page.
Join PM Evangelist, Axel Sooriah, & Product Ops. Consultant & Advisor, Jenny Wanger, as they unpack the role of product ops and discuss key takeaways in Atlassian’s ‘The Product Ops Mission’ guide. They’ll answer your questions live on May 6 at 9:00am PT.
Register here ⬇️Online forums and learning are now in one easy-to-use experience.
