jira automation - email sending for ticket with nearing due date
Jihoon Kim _김지훈_
June 15, 2023
Hi, I am trying to use jira automation to send email to the team members who have tickets nearing the duedate and separate email for the overdue tickets.
To do so, I made two automation
1. email sent for tickets that has due date of less than 2 days
2. email sent for tickets that has due date passed.
The second one works without a problem, but I have a problem with the first one.
Scheduled
cron : 0 0 8 ? * 2-6 *
JQL : status!="done" AND assignee!="empty"
IF : Advanced compare condition
{{issue.duedate.jiraDate}}
less than
{{now.plusDays(3).jiraDate}}
------------------------------------------up to this part works well
But the problem was that this function also sends emails to the overdue ticket, so team members were getting 2 emails for the same ticket.
So I added the second condition------------------------------------------------------
AND : Advanced compare condition
greater than
{{now.jiraDate}}
Then: Send email
After I added the AND : Advanced compare condition, it no longer sends emails to anybody.
I double-checked that there are tickets that meet the criteria by using the following JQL on my board.
status!="done" AND assignee!="empty" AND duedate<= 2d AND duedate >= now()
there are at least 30 tickets
I appreciate any input.
Thank you.
Alisa Zamaraeva
June 16, 2023
Hi @Jihoon Kim _김지훈_
As I understand you get the right set of issues when filtering with this JQL:
So you can try using the same JQL inside the CRON trigger instead of using status!="done" AND assignee!="empty" .
If you want to filter issues with separate action, you can run the same query inside If condition within the rule.
Hope this helps.
Trudy Claspill
Hello @Jihoon Kim _김지훈_
Can you share with us the details of the Audit Log for an execution of the rule where there were issues that met the conditions but no email was sent?
Deepak Jain
You can also accomplish that by using Jira automation also:
  • Go to project settings > Automation
  • Create new rules
  • Trigger: Schedule
  • Choose e.g. to send it one time a working day, at a specific time
  • Click "Run a JQL search and execute actions for each issue in the query."
    • Write your JQL "duedate = startOfDay("+2d")"
    • Validate your query to see that it provides results
  • Add new action "Send email"
    • Compose your email and use smart value to enhance it
    • Choose the recipients (assignee/reporter etc)
Test it before of sending actual emails to people. Hope that helps you.
Jihoon Kim _김지훈_
June 15, 2023
Please read the post thank you.
I am not just trying to send an email. (I can do that already)
what I am trying to do is to figure out why
less than
greater than
{{now.jiraDate}}
These two condition does not work
my intention is to send an email for the ticket that has duedate between today ~ the day after tomorrow.
but not for the one with over the duedate.
Deepak Jain
Hi @Jihoon Kim _김지훈_  -- Welcome to the Atlassian Community!
You could do this with a saved filter and subscription (Without automation):
project = myProject AND duedate = startOfDay("+10d")
To learn more about filter subscriptions and advanced JQL, please look here:
Cheers !!
