jira - automation - if assignee comments
Gavin
June 9, 2023
is there a way to trigger an automation if the assignee of the issue comments on an issue?
said kouzibry
June 9, 2023
Glad to hear you found a solution,
I suggest using {{assignee.accountId}} equals {{initiator.accountId}} instead of displayName.
Tim Perrault
June 9, 2023
Use the issue commented trigger, but then have a condition and I would use the JQL condition with this JQL:  assignee = currentUser()
Tim Perrault
June 9, 2023
Actually, never mind that doesn't work for some reason.
Tim Perrault
June 9, 2023
Figured it out, you can use the advanced compare condition.
