jira fisheye smart commit transition
Christian Best December 4, 2012
<label style="margin: 0px -190px 0px 0px; padding: 4px 0px 0px; border: 0px; outline: 0px; font-size: 13px; vertical-align: baseline; float: left; display: block; left: -200px; line-height: 1; position: relative; width: 190px; text-align: right; color: #333333; font-family: arial, tahoma, verdana, sans-serif;">JIRA Issue Transitions</label>I have activated the transition condition that only with commited code an issue can be done. But allthough I activated smart commits in fisheye for transition condition it is not possible to finish an issue. Of course I also connected Jira and Fisheye in both directions.
I put the jira issue number infront of the commit. Jira shows the commits in the tab "git commits" and also the fisheye message appears in the activity stream in the dash board. But still it is not possible to do the transition.
Are there any more configurations I have to do?
Felipe Kraemer
November 18, 2014
Hi Christian,
In order to transition a JIRA issue from a smart commit, you need to specify the JIRA issue key and the transition you want to execute. For example:
JRA-123 #resolve
If there are no communication problems between FishEye and JIRA, FishEye should resolve the JIRA issue JRA-123 in the example above.
I hope this helps!
Sergey Svishchev
April 11, 2013
Probably a bug in a.a.c, report it to Atlassian if you like
Why do I have the label style tag in my questions? I did not put it there and if I edit my question I can not delete it.
