jira issue collector style
viktoriia_lysenko October 16, 2020
Good day. Our company made up our mind to use Jira Issue Collector. Is it possible to change the view of the template, add its own styles?
viktoriia_lysenko October 19, 2020
@Carlos Garcia Navarro I see now, that it's possible to add only your own trigger. But when it comes to adding your own template preview, we don't have such a possibility. Right? I mean, not only change the order of fields or show/hide them, but style the fields using the design, colors on your site.
I found the plugin ReVitalized Issue Collector for Jira which can help up to add own styles. But I can't figure out how to add it into our application. Does anybody have a chance to work on it? Thank you.
https://marketplace.atlassian.com/apps/1221494/revitalized-issue-collector-for-jira?hosting=server&tab=overview
Hi @viktoriia_lysenko ,
If you go the project settings-> issue collectors, you have different options for the trigger (including a custom one). Is this was you're looking for?
Also for the feedback form:
This article has details about the advance use of issue collectors:
https://confluence.atlassian.com/adminjiracloud/advanced-use-of-the-jira-issue-collector-788726105.html
And this other post includes good example on the use of custom issue collectors:
https://community.atlassian.com/t5/Jira-questions/Issue-collector-does-someone-has-an-example-how-to-use-the/qaq-p/293723
Hope it helps,
