Good day. Our company made up our mind to use Jira Issue Collector. Is it possible to change the view of the template, add its own styles?
@Carlos Garcia Navarro I see now, that it's possible to add only your own trigger. But when it comes to adding your own template preview, we don't have such a possibility. Right? I mean, not only change the order of fields or show/hide them, but style the fields using the design, colors on your site.
I found the plugin ReVitalized Issue Collector for Jira which can help up to add own styles. But I can't figure out how to add it into our application. Does anybody have a chance to work on it? Thank you.
Hi @viktoriia_lysenko ,
If you go the project settings-> issue collectors, you have different options for the trigger (including a custom one). Is this was you're looking for?
Also for the feedback form:
This article has details about the advance use of issue collectors:
And this other post includes good example on the use of custom issue collectors:
Hope it helps,
