In issue navigator how do you reset columns to the default columns?
More specifically I'm attempting to add the "status" column back and when I try to add it by typing "status" it stops at columns that start with letter "R" and says "28 more options. continue typing to refine further."
Any help in adding that "status" column for the jira issue would be appreciated.
Actually.
It was simple. When you click on columns instead of typing the column. Click on "Restore Defaults"
Hi Gavin,
this link might be useful for getting the default columns for the issue navigator: https://support.atlassian.com/jira-cloud-administration/docs/configure-the-default-issue-navigator/
As well, there is a bug registered for this: issue: https://jira.atlassian.com/browse/JRACLOUD-59412
and workaround is given there:
Hope this will be useful for you!
