jira-issues-disposition for Jira 6
Adrian Stoker
January 21, 2015
Is this product supported for V6 of Jira?
It appears to have installed etc, however when I try and modify the Jql for the custom field configuration I get a 404 error page.
teilor_soares
January 21, 2015
Hi Adrian. The latest version of jira-issues-disposition isn only compatible with with JIRA 5.1, so I believe you may find some problems using this plugin with newer versions of JIRA.
-Teilor
