jira oauth with python
M S April 22, 2019
I'm creating an application integration with python flask and jira. I wanted to do authentication with oAuth 2.0 to authenticate my users with Jira. is there any full example for that?
I found an example which is incomplete:  https://jira.readthedocs.io/en/master/examples.html#oauth
key_cert_data = None
with open(key_cert, 'r') as key_cert_file:
    key_cert_data = key_cert_file.read()
oauth_dict = {
    'access_token': 'foo',
    'access_token_secret': 'bar',
    'consumer_key': 'jira-oauth-consumer',
    'key_cert': key_cert_data
auth_jira = JIRA(oauth=oauth_dict)
But how can I generate key_cert_file, access_token, access_token_secret and consumer_key?
or is there any better way or version of this?
M S April 23, 2019
please guys, help me.
Lokesh Naktode_miniOrange
Hi @Maziar Sojoudian ,
Right now, JIRA does not have default support as an OAuth 2.0 Server/Provider but you can extend the JIRA's functionality to make it work as OAuth Server(OAuth 2.0) with our OAuth plugin.  Please reach out to miniOrange at info@miniorange.com with your use case so that we can provide you with our plugin and integration steps.
Lokesh
Full disclosure: I work for the miniOrange.
