jira.permission.comment Questions
Mark Almeida-Cardy April 29, 2020
Hello all.
I have a workflow that I would like to block comments on a certain status and only allow comment within certain transitions.
Within the workflow, I have added the follwoing to a status.
Status - IN REVIEW
Status properties
jira.permission.comment.denied = ''
This works as expected.
Now I want to Transition to a status of REJECTED and present the comment screen on transition.  So I tried adding the following to the transition.
jira.permission.comment.assignee = true
The result is this.
Any ideas on how to go about this?
Hannes
Hi @Mark Almeida-Cardy
currently I'm trying to hide the comment section on a transition screen. This is not possible by configuration, so I thought about jira.permission.comment.denied and saw your post here.
I didn't get this solved, but on your screenshot I see a screen without a comment section. How did you achieve this?
When I'm adding jira.permission.comment.denied to the screen a comment will not be saved, but the section is still visible.
Thanks for your hint here!
Best,
Hannes
Gonchik Tsymzhitov
Looks like you made a typo
Ah yes.  thank you for that.  Typo corrected but I still have the same results.
Is my approach to this correct?
Gonchik Tsymzhitov
Just please, remove that attribute, if you want to show comment screen
and define the screen for that transition
https://confluence.atlassian.com/adminjiracloud/defining-a-screen-776636475.html
Thank you for your suggestions so far.
When you suggest to "remove that attribute" which one are you referring to?
With the following applied on the status, comments are not possible (as desired)
However, I was hoping that applying the following on the transition would allow for the assignee to add a comment on the transition screen.
However, this does not work.
Like dshvedchenko likes this
