jira permission to unlink issues
Bahar çağlar November 25, 2013
I am using issue linking (in jira 5.2.11). How can I disable delete this link button on the view screen? (image below)
Actually, the reason is that there is no settings in the permission scheme to allow/restrict users to delete issue links.
The only permission type is link issues.
Where is the permission for delete links?
Thanks.
RambanamP
November 25, 2013
you can try with permission based on workflow steps,
http://www.j-tricks.com/1/post/2011/02/permissions-based-on-workflow-status.html
i have't teied that, you can try somthing like this
jira.permission.link.delete.group.1=some-group-one
Bahar çağlar December 3, 2013
sorry, I cant understand... where should I write this property in the workflow?
RambanamP
December 3, 2013
thanks, it works.
Vladimir Chernyakov
May 5, 2014
Hi Bahar!
Can you say, what configuration do you use finally for that?
artafon September 22, 2016
Hi friends!
can you help us, what is configuration finally?
Eric Pratt October 3, 2016
For those still wondering what the final configuration is, here is what worked for me:
Property Key: jira.permission.link.user
property Value: jira.permission.delete.user=username
Of course you can use group or projectrole or whatever works for you.
Like Maciej Trzuskolas likes this
artafon October 7, 2016
Eric Hi!
Thx for your reply.
Maciej Trzuskolas
April 16, 2019
Hi @Eric Pratt1  , you just saved me hours of debunking it myself :) THANK YOU
