jira problem after installation is not displayed in browser
Fernando del Río April 13, 2016
Hello everyone,
Install jira 7 in centos 6 postgres 9.3 and 1.8 java
the installation is correct, but when I want to see jira in my browser nothing appears.
Catalina.out ends well:
    JIRA 7.0.9 build: 70119 started. You can now access JIRA through your web browser.
2016-04-13 09:12:17,621 localhost-startStop-1 INFO      [c.a.jira.scheduler.JiraSchedulerLauncher] JIRA Scheduler not started: JIRA not setup yet.
2016-04-13 09:12:17,643 localhost-startStop-1 INFO      [c.a.jira.startup.LauncherContextListener] Memory Usage:
      Heap memory     :  Used:  363 MiB.  Committed:  687 MiB.  Max:  746 MiB
      Non-heap memory :  Used:  197 MiB.  Committed:  215 MiB.  Max: 1264 MiB
      TOTAL           :  Used:  561 MiB.  Committed:  902 MiB.  Max: 2010 MiB
13-Apr-2016 09:12:17.911 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
13-Apr-2016 09:12:17.922 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 50167 ms
2016-04-13 09:12:20,908 Modification Check:thread-1 INFO      [c.a.jira.startup.JiraStartupLogger]
    ___ Modifications ___________________________
         Modified Files                                : jira-application.properties
         Removed Files                                 : None
2016-04-13 09:14:07,121 hipchat-plugin-tasks-executor-0 DEBUG      [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] getService bundle [com.atlassian.plugins.b        ase-hipchat-integration-plugin-api]
Help Please!!!!!
Thanks you
Nic Brough -Adaptavist-
April 13, 2016
The message there says it's started the application, and you should be able to use it.  A blank screen when you visit it implies it's not quite ready yet (especially if you get a spinner and not just a simple blank), or that you're on the wrong url.
How did you do the install (installer? .zip expansion?).  And where are you pointing the browser?
The installation was carried out with:
-Centos 6
-atlassian-jira-software-7.1.4-jira-7.1.4-x64.bin
and he had no problem after installation a message appeared: "Jira install ok now access http: // localhost: 8080"
I'm in my browser accessed by ip andress http://xxx.xxx.xxx.xxx:8080
and a blank screen appears, the error is time out
April 13, 2016
Hmm, a timeout implies something is running, but not yet responding.  If it's because of errors, there should be something in the log by now
catalina out only shows this:
April 13, 2016
Ok, that looks healthy I think, what about atlassian-jira.log in the <JIRA home>/log directory?
equal  to catalina.out
April 13, 2016
Hmm.  It shouldn't be.  It should be telling you what is happening internally.  Is the CPU or memory maxed out?
this very strange, reinstall everything from 0 again and you commented how it goes
Fernando del Río April 14, 2016
Hi nic,
reinstall everything, run the installer on tour and catalina.out is here:
server startup in 36140 ms.
I'm trying to access from the browser (http://xxx.xxx.xxx.xxx:8080)  and not working
April 14, 2016
Errors, not found or blank screen and spinning?
browser in blank and the only detail in catalina.out:
INFO /var/atalassian/application-data/JIRA is validated and locked for exclusive use by this instance
April 14, 2016
What do the last 20 lines of catalina.out say, and the last 20 lines of atlassian-jira.log and, what is the computer doing?  Is the memory and/or CPU maxed out and being thrashed?
This es mi catalina.out:
                                                        asm-*.jar,
                                                         dom4j-*.jar,
                                                         icu4j-*.jar,
                                                         jaxen-*.jar,
                                                         jdom-*.jar,
                                                         jetty-*.jar,
                                                         oro-*.jar,
                                                         servlet-api-*.jar,
                                                         tagsoup-*.jar,
                                                         xmlParserAPIs-*.jar,
                                                         xom-*.jar
         user.country                                  : US
         user.dir                                      : /opt/atlassian/jira/bin
         user.home                                     : /home/jira
         user.language                                 : en
         user.name                                     : jira
         user.timezone                                 : America/Santiago
2016-04-14 13:33:22,251 localhost-startStop-1 INFO      [c.a.jira.startup.JiraHomeStartupCheck] The jira.home directory '/var/atlassian/application-data/jira' is validated and locked for exclusive use by this instance.
2016-04-14 13:33:22,265 localhost-startStop-1 INFO      [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/jira/dbconfig.xml
2016-04-14 13:33:22,405 localhost-startStop-1 INFO      [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/jira/dbconfig.xml
2016-04-14 13:33:22,785 localhost-startStop-1 INFO      [c.a.jira.startup.JiraStartupLogger]
    ___ Starting the JIRA Plugin System _________________
2016-04-14 13:33:22,787 localhost-startStop-1 INFO      [c.a.plugin.manager.DefaultPluginManager] Plugin system earlyStartup begun
2016-04-14 13:33:25,889 localhost-startStop-1 INFO      [c.a.plugin.loaders.ScanningPluginLoader] No plugins found to be deployed
2016-04-14 13:33:26,102 localhost-startStop-1 INFO      [c.a.plugin.util.WaitUntil] Plugins that have yet to be enabled: (12): [com.atlassian.auiplugin, com.atlassian.plugins.issue-status-plugin, com.atlassian.plugins.less-transformer-p$
2016-04-14 13:33:27,262 localhost-startStop-1 INFO      [c.a.plugin.manager.DefaultPluginManager] Plugin system earlyStartup finished in 0:00:04.470
2016-04-14 13:33:27,575 localhost-startStop-1 INFO      [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/jira/dbconfig.xml
2016-04-14 13:33:27,603 localhost-startStop-1 INFO      [c.a.j.instrumentation.external.DatabaseExternalGauges] Installing DBCP monitoring instruments: DatabaseExternalGauges.JiraDbcpInstruments[instruments=[DBCP_MAX, DBCP_ACTIVE, DBCP_$
2016-04-14 13:33:27,705 localhost-startStop-1 INFO      [c.a.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2016-04-14 13:33:27,709 localhost-startStop-1 INFO      [c.a.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully.
2016-04-14 13:33:27,763 localhost-startStop-1 INFO      [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is not yet configured
2016-04-14 13:33:27,763 localhost-startStop-1 INFO      [c.a.j.config.database.DatabaseConfigurationManagerImpl] Enqueuing Database Checklist Launcher on post-database-configured-but-pre-database-activated queue
2016-04-14 13:33:27,765 localhost-startStop-1 INFO      [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is not yet configured
2016-04-14 13:33:27,765 localhost-startStop-1 INFO      [c.a.j.config.database.DatabaseConfigurationManagerImpl] Enqueuing Post database-configuration launchers on post-database-activated queue
2016-04-14 13:33:27,807 localhost-startStop-1 INFO      [c.a.jira.startup.LauncherContextListener] Memory Usage:
      Heap memory     :  Used:  191 MiB.  Committed:  482 MiB.  Max:  738 MiB
      Non-heap memory :  Used:   56 MiB.  Committed:   58 MiB.  Max: 1264 MiB
      TOTAL           :  Used:  247 MiB.  Committed:  540 MiB.  Max: 2002 MiB
14-Apr-2016 13:33:33.537 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
14-Apr-2016 13:33:33.543 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 36140 ms
Fernando del Río April 22, 2016
hi Nic
The problem was the firewall machine thank you very much
David_Hespelt
October 23, 2016
okay the problem is the firewall, but what did you do to the firewall machine to fix it?  Inquiring minds want to know
CiSOFT
September 13, 2016
Even Centos 7 and atlassian-jira-software-7.1.4-jira-7.1.4-x64.bin presents the same problem
Server boot up hangs at
         Modified Files                                : jira-application.properties, seraph-config.xml
2016-09-13 13:06:38,948 hipchat-plugin-tasks-executor-0 DEBUG      [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] getService bundle [com.atlassian.plugins.base-hipchat-integration-plugin-api]
gangadhar mamillapalli
am facing same issue while running ==> "atlas-debug" on my plugin,  server starts and get hangs in middle at following line ==>
[INFO] [talledLocalContainer] 2016-06-15 10:58:42,444 hipchat-plugin-tasks-executor-0 DEBUG      [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] getService bundle [com.atlassian.plugins.base-hipchat-integration-plugin-api]
and finally time outs .
thanks
-Centos 6
