Hi, i've just installed the jira software in my server,
But right now whenever i want to create a project, there's only this 3 project selection, very few compare to the cloud one, is there anything i'm missing when installing the Software ?
regards
Hi @van seo,
Since you said you just installed Jira Software, have you checked to make sure that you have given your user account access to use the Jira Software functionality?
You can see this by going to the Admin Cog -> Applications
Then click on the Application access link on the left hand pane.
You should get a screen that looks like this:
I hope that helps!
-James
so that screenshot is for Business projects. Do you receive a screen prior to that allowing you to choose say Software project templates? What type of project do you need?
i need to create software project with scrum template.
whenever i'm clicking create project, only shows that options in screenshot, even if i'm creating project from Software under Projects menu dropdown.
talk to your admin. It may be that they have restricted project creation by templates
one other possibility is that you have install Jira Core and not Jira SW.
