make field required based on another field using behaviours plugin bug?
fabby
my jira version is 4.4.1,behaviours plugin version is 0.5.0
1. there are two fields:'ToolType' and 'Description'.
'ToolType' is of Cascading Select type , and it has set its first default value as Camera,the second default value is not set.
'Description' is of Text Field type.
2. i want to make 'Description' required when 'ToolType' select value Camera
i wrote the following code
FormField tl = getFieldById("customfield_11500")
FormField des = getFieldById("customfield_11501")
if (tl.getValue().contains('Camera')){
 des.setRequired(true)
}else{
 des.setRequired(false)
problem one:
on create screen,'Description' is not required,although 'ToolType' has default value Camera.
problem two:
when choose LCD as 'ToolType' value, 'Description' is not required. click 'Description' text box, it is still not required as expected.
while once i have choosed Camera as 'ToolType',of course 'Description' is shown required.
then i choose LCD,'Descrption' is shown unrequired as expected.but when i click the 'Description' text box.it is shown required !!! and later 'Description' will display required as long as it is clicked ,no matter what 'ToolType' is chosen.
fan September 8, 2015
Hi Jamie, I am facing the same sitaution with select list field. I have already raised it in the forum https://answers.atlassian.com/questions/24646237 Colud please suggest a solution for this. Thanks and Regards Neena
JamieA
September 8, 2015
We are adding support for cascading selects, it will be released soon.
NeenaR September 7, 2015
Hi Anyone found a solution for this? Thanks Neena
Andrei [errno]
April 10, 2013
have you figured out the solution to your problem?
JamieA
January 6, 2013
> if(tl.getValue().contains('Camera')){
Log to your console t1.getValue(). As it's a cascading select you are probably getting a map or a list. But if you add some debug either you will figure it out or I will be able to.
fabby
FormField jl = getFieldById("customfield_11500")
FormField des2 = getFieldById("description")
if (jl.getValue().contains('Camera')){
 des2.setFormValue(jl.getValue()+"\nfirst\n"+jl.getValue().contains('Camera'))
}else{
 des2.setFormValue(jl.getValue()+"\nsecond\n"+jl.getValue().contains('Camera'))
my step:
create issue
choose LCD,desc2 shows 'LCD,' .click the 'Description' text box,it is not required.
then choose Camera,desc2 shows 'Camera,' .'Description' is required.
choose LCD,desc2 shows 'LCD,' click the 'Description' text box,it is required.
fabby
anyone can git any idea??
JamieA
January 8, 2013
What's the question? I don't understand your comment above, and I don't see the debug lines I recommended.
