migrate projects from jira data centre to jira cloud
Veerapindi Satyanarayana September 18, 2025
step by step process, please assist me
2 accepted
4 votes
Prachi Bolar
September 19, 2025
Welcome to Community :)
Please find the detailed article on migrating projects from DC to cloud
https://community.atlassian.com/forums/Jira-articles/Step-by-Step-Guide-Migrating-Jira-Data-Center-to-Jira-Cloud/ba-p/2925735
Thank You,
Prachi
3 votes
Benjamin
Hi @Veerapindi Satyanarayana ,
Every instance is different and there isn't a one size fits all template for all migrations. It will primarily depend on the marketplace apps you have, integration, your Jira data profile.
Learning about Atlassian Migration tool will be the first start:
https://support.atlassian.com/migration/docs/jira-cloud-migration-assistant/
If  there's any issues with the tool, would recommend raising a support ticket with Atlassian.
Trudy Claspill
Adding to what @Benjamin has said...
Disclaimer: I work for an Atlassian Platinum Solution Partner - Praecipio.
If you feel overwhelmed and are looking for more customized and personalized assistance with your migration you can consider engaging an Atlassian Solution Partner. You can find a directory of partners here:
Atlassian Partners Directory
You can filter by geographic region and solution offerings (i.e. Cloud migrations).
Partners can engage at various steps in the process to the degree you need:
- assessing your environment to highlight risks
- estimating effort
- creating runbooks for the migration of the data itself, and guidance for how to handle the elements not handled by the Jira Cloud Migration Assistant
- preparing your users for the change, as Cloud is very different visually from Data Center
Like Prachi Bolar likes this
