×while moving issue from one project to another
i want to fill custom fields, how can I do this?
Hello @Lin Debby
When you move the issues to another project then you will be prompted to fill the mandatory fields, thus if the custom fields are mandatory for the target issueType then you can fill them.
From the docs
