Hi @hitakshi , It will only impact the incoming mail handler, you need to check the incoming mail configuration and use the supported TLS version. All the supported version is listed here in this article https://support.atlassian.com/security-and-access-policies/docs/supported-security-protocols-for-atlassian-cloud-products/#Supported-cipher-suites , Have a look . Thanks
Hello @hitakshi
Take a look at the answer on this post to see if that helps.
Dear Team & Community,
In order to check if our JIRA will be impacted or not by this TLS cipher depreciation, could you tell me how can i check it?
Do you have any guideline which can explain step by step where and what to check?
