(assignee = robind AND status not in (Closed, Received, Reviewing, "In Committee")) OR (assignee = robind AND labels not in (PSG, Triage))
I'm still getting tickets that have the labels indicated above.
Thanks.
To combine them back together, use lots of braces to force the correct reading:
assignee = robind and (
( issuetype = "business analysis" and status not in (Closed, Received, Reviewing, "In Committee") )
or
( issuetype = "client support" and labels not in (PSG, Triage) )
If that doesn't work, then you need to do some debugging on what is going wrong - what issues are missing when they should be selected, and what are left out when they should be there?
Nic is close, if you try to exclude labels you need also to include empty labels.So the part ( issuetype = "client support" and labels not in (PSG, Triage) ) should be ( issuetype = "client support" and (labels not in (PSG, Triage) or labels is empty) )
Yes, sorry, I'm very fuzzy on searching labels because I tend to use labels in a really simple way. When I'm searching labels, the clause is almost always "label = x", and I forget that searching for negative labels is possible.
This is not working either, unfortunately. Maybe if I explain in non query language what I'm trying to do, a proper query can be written by someone who knows what to do.
I want to see two types of tickets:
Also, if I try to query just on the second bullet assignee = robind and project = "Client Support" and labels not in (PSG, Triage) I don't get the proper results. There's something about this second part that I can't get right.
There are some discussions here about the "Labels" part https://confluence.atlassian.com/display/JIRA/Advanced+Searching Searching labels is yes, a bit tricky.
